DS 4.5 Instance Spacing
barbultbarbult Posts: 27,473
How can I control the spacing between my instances when I use "Create new node instances" in DA 4.5? I'm Using the latest Beta 4.5.1.41 on Windows 7 64 bit. I created 10 instances, and they are spaced very far apart.
  • larsmidnattlarsmidnatt Posts: 4,511
    i always edited them by hand...even if they let you control the spacing, I often need to change rotations and height and stuff. But yeah if there is a way to automatically have it change that stuff would be nice.
  • SzarkSzark Posts: 10,634
    So far manual placing I am affraid.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Try using the Align pane - still a two step process, of course, but if you want regular spacing it may help. You could also look at Send in the Clones 2.
  • barbultbarbult Posts: 27,473
    Thanks, the align pane was new to me. I played around with it some, and I think it will help.
  • BWSmanBWSman Posts: 0
    Except it doesn't seem to work (instancing; that is using SITC). :down:
