Morphing trouble on Zbrush
Hey! I just gor Zbrush which is awesome. I did a morph of a body suit for one of my character that had sticky clothe on breast (u kno what I mean). I'm very happy with the morph result. I import it in Daz, pull on the slider and it doesn't do at all what I sculpted.. Is it possible to morph something which is not zero shaped?? :/
thx a lot
Edit: I dont use GoZ .. doesnt seem to work. Instead I use the morph loader pro.
And also, The morph works well when the suit is not fited to the figure.
If the figure isn't in the zeroed state (pose and morphs) you need to use the Reverse Deformation option on importing. I suspect tnat may be your issue, but there isn't a lot of information to go on.
That was the problem thx! found info about reverse deformation thing. That does it
