two questions - iray thumbnail generation? destination file naming text behavior
hey there--
two quick questions about default daz studio behaviors that i'd love to change:
a) is there some setting that will get studio to generate iray thumbnails when saving a file? manually generating/naming/placing them is a drag and a half.
b) is there a setting to allow text entry in the render settings destination file naming window to behave normally--without jerking the cursor back to the end of the file name automatically every time a character is entered?
any and all help wrangling these will very much appreciated.  thanks!
j
  • a) not that I am aware of
    b) this has been reported as a bug, but it may be worth a reminder (assuming it is still an issue in the new beta).
  • jardinejardine Posts: 1,223
    thanks, richard...
    i'll re-report b) as a bug...the behavior is still present in the beta.
    j
    It is same about LPE Expression  input box too.
  • barbultbarbult Posts: 27,499
    a) V3Digitimes has a Super Save product that will generate beautiful Iray thumbnails and even tip files (the larger view you get when hovering over the thumbnail). I use Super Save so often that I even redefined my Ctrl-S shortcut in Daz Studio to use Super Save Incremental Pro. I can still access the normal Save and Save As from the DS menu in cases where I don't want to use the incremental save.
    b) I reported this many many versions ago, and it has still not been fixed. It seems like it would be a simple fix, but it is so frustrating! Thank you for reporting it again.
    b) It's really a Qt 4 problem that isn't really fixed until Qt 5 (which has a couple of other UI fixes, too...but is a MAJOR update for Studio...as in needs a new SDK type update)
    It would be nice if We received a response like that to our repeated bug reports! Thanks for the info.
    barbult said:
    a) V3Digitimes has a Super Save product that will generate beautiful Iray thumbnails and even tip files (the larger view you get when hovering over the thumbnail)...
    thanks, barbult--solution deployed!  life feels better already!
    and thanks, mjc1016.  that certainly puts the issue in perspective.
    j
