"Flying Steamer" obp file... converter?
I have Bryce 7.1 installed, but it won't open the Flying Steamer's .obp file, and it doesn't seem to want to open any of the other files in the directory structure.  Neither does DAZ Studio 4.9 (and it won't show up in Smart Content).
I looked up info on the .obp file format, and the interwebs says Bryce 5.  Then I looked up Bryce 5 to 7 conversion, and didn't see any obvious articles.
I figured I would put the ship in Bryce, then send to Studio, but since that isn't working, I figured I'd ask the Forums.  Thanks!
  • MelanieLMelanieL Posts: 7,892
    edited November 2016
    Certain types of Bryce files need to be installed in a particular location - .obp files are one of these. DIM does not always place these things in the correct position. There is a useful document written by Horo (a PA whose makes products for Bryce sold here at DAZ3D) which you can find on his website here: https://horo.ch/docs/sys/index_en.html#DocTop - you want the Bryce FAQ from the "Bryce Documents" - "Mine (PDF)" -  "Diverse" section (click on the links down the left hand side). This explains where to put different types of file so Bryce can access them.
    Post edited by MelanieL on
    If it is an OBP it needs to be placed into your object presets library.  You can do this by importing it from withinn bryce, having unzipped it to a temp folder on your computer.
    Post edited by Chohole on
