one single shader
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
hello!!! I have a scene full textured, and I want to get a render from it in "clay", withiourt any shaders, except the grey clay... there is a more simple way than select each of the objectsq? (they are hundreds of items!)... thank you!!!
  • 3DAGE3DAGE Posts: 3,315
    Hi Celmar :)
    First,... Save your scene, .. :)
    Then go to the shaders panel at the bottom right,. open it up and select the shaders (hold shift and click each shader to select them) and delete them all apart from the Default shader.
    Change that Default shader,. to your clay shader.
    When you delete any Master shaders,... then any object has to use the "Default" shader.
    If that;'s the only shader available, then it'll be applied to all objects in the scene
    save your scene as a different file name.
    Hope it helps :)
    1280 x 1024 - 212K
  • laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
    thank you, 3d age!!! perfect for me!!!
    I believe the other trick to getting those nice "clay" renders is using ambient occlusion in the render settings. At least that's what I recall reading.
