merging multiple subtools into 1 model
Cichy3D
Sorry I did not know how you call this process. What I'm trying to do is bring in a model from zbrush that has multiple parts to it and save it as a figure in daz. I brought in a chair which had lining that I parented to the chair but when I saved it and loaded up it only loaded the chair. I'm trying to bring in a creature where the teeth and eyes would be seprate and editable but load up and be recognized as a part of the creature.
Also, when it comes to teeth how would you bind that to the jaw
Post edited by Cichy3D on
You are using the GoZ Bridge? You should probably be exporting from ZBrush as OBJ, makign sure you have each part set to export as a group, then use the Figure Setup pane to rig it as a figure (which answers your second question too).
Yeah I'm using Goz Bridge but it only sends the currently selected subtool. There's an option to send all of them as a group?
Not ot my knowledge, as I said I think you should export as OBJ and then import that into Figure Setup.
