Oberon Station missing files.
Obeon Sation (SKU:35331)
When I try to load in the corridor I get a missing file error message. It hapens with the 3 individual corridors (props), also the sets. The example below is when I want to load in the 3Delight prop.
data/petipet/sci-fi base/corridor/Сorridor1.dsf
Thanks You.
Richard Taylor
  • Joe WebbJoe Webb Posts: 837
    I put in a Help request on this a few days ago. I just noticed, playing around with the set otherwise, that there is something wrong with the sufaces/materials for the terrain that comes with the set. It loads in white and won't accept the Iray or 3DL surfaces supplied in the set. They seem to load, and are in the surface tab (bump, diffuse channels, normal map) but still render only white. I tried appying a geo shell and applying the texture to that - but still all white.
  • Thanks Joe.
    Its just good to know I'm not the only one getting the Corridor problem. I thought it might have been a bad download (even thought I deleted and reloaded)
  • JennKJennK Posts: 834
    I am getting the Corrodor problem as well. just downloaded it and tried using it last night. sad
  • thd777thd777 Posts: 946
    edited November 2016
    If you don't want to wait for a fix, I solved the problem the following way:
    - Download and install the Poser version (can be in a temporary location)
    - Load the corridor as Poser file. That works.
    - Now apply the DS material (either Iray or 3DL)
    - Save the new corridor as scene asset in the same directory as the rest.
    - If you want to fix the pre-loads, just load one, load the fixed corridor and copy/position it at each of the gray place holder boxes, then delete those. Now save the the pre-load as scene asset.
    That way you have a fully working set in a few minutes.
    - If you want to fix the terrain shader, I simply replaced the shader with one of the Terradome ones. That looks very good.
    Ciao
    TD
    1800 x 822 - 2M
    Post edited by Chohole on
  • Thanks CD
    Great image. Thanks for that fix.
    Thanks for the Fix. Love the image.
  • OstadanOstadan Posts: 1,130
    Recent update finds the file, but it still shows up as if it weren't there, i.e., just a bounding block that renders nothing.  I uninstalled and reinstalled, to no avail.  Am I overlooking something??
