Shadows around the Iris
DrowElfMorwen
Can anyone tell me why I mgiht be seeing a shadow around the iris on my Genesis (1) figure?
http://orig06.deviantart.net/9b0d/f/2016/309/2/b/test6_by_drowelfmorwen-dandnth.png
There are no settings I have found that should be causing this, unless I am completely missing something. :/ I even see the shadow in the viewport on "smooth shaded".
It's not a shadow...it's the iris itself.
If there are any iris correction morphs, you'll need to apply them..
I actually DO have a correction morph applied... :( There's only one to apply, too.
Then you need to tweak it...it's rather finicky. Especially if you've enlarged the eyes. You may need to actually go to negative values on it.
On a Genesis morph I was working on, one with enlarged eyes, I used a small negative value to get rid of the 'shadow' I can't remember if it is a percent or decimal for the morph, but it would be the equivalent of about -1%.
