Iray changing from GPU to CPU rendering , why?
Ok here is my issue, maybe others have the same case.
I have a GTX780Ti, does very well on iRay, after the 6th render it changes to CPU rendering and obviously renders like a turtle.
I'm using the Beta version .117, maybe is due to that?, I've seen doing the same with the General Version.
is there a memory saturation?, there is a script to purge the Gpu memory?
any help will help, se habla español.
1339 x 809 - 2M
    Leaving renders open after rendering will eventually use up all the card's memory and drop to CPU mode.
  • namffuaknamffuak Posts: 4,529
    If you are leaving the render windows open after the render they hold onto the memory on the gpu. Check the log (help -> troubleshooting -> view log); scroll to the bottom and then back up to where the last render started; you're looking for 'memory allocation error' or something close to that.
    If this is the case, just closing the render windows will free the memory.
  • OK, lemme try your advices,
    thanks for the fast help! cool
  • nicsttnicstt Posts: 11,715
    Download GPUz; that will tell you how much is beeing used.
    I always have a scene open; it means they start about a minute faster. and the viewport preview starts faster too.
    I only close when the scene only just fits onto the card; with a 980ti, it's more often than I like, but not too bad.
    I have GPU-Z but never paid attention to the data displayed, when rendering I monitoring temperatures with MSI Afterburner instead, but I'll try on my next projects
    btw, mjc1016 and namffuak were right, the issue was the open window, now I do 2 options, saving the unfinished image or select X, thanks!
