Z whimsical props rectangle
Allegra
in The Commons
Hi, I'm having a problem with Z Whimsical - Props & Poses...the props
I've re-installed a few times and this is what happens when you load the cage or the lantern prop.
Any help appreciated:(
383 x 538 - 64K
What is the error message, if any?
What does the log file say Help > Troubleshooting > View Log?
Thanks mjc...I didn't even know the log file was there...here it is
2016-25-30 11:25:12.016 WARNING: fileinput\dzassetdaz.cpp(10673): Could not find UV set definition: /data/Zeddicuss/Z_Whimsical_Props_and_Poses/BirdCageRH/UV%20Sets/Zeddicuss/Base/default.dsf#default
2016-25-30 11:25:12.016 WARNING: fileinput\dzassetdaz.cpp(1864): Could not find UVs for geometry.
2016-25-30 11:25:12.016 WARNING: fileinput\dzassetdaz.cpp(4698): Could not find geometry for the material instance.m_uri.
2016-25-30 11:25:12.016 WARNING: fileinput\dzassetdaz.cpp(1322): Failed to create material!
You can ignore the 'failed to create material' ones...they are caused by...
So the next question, if you navigate there in your OS file manager, is the file there?
If it is...can you post a screen shot of your mapped content folders...
If it isn't there...file a bug report.
Thanks mjc..will have a look for it otherwise file a bug report...:)
