how to use Jepe's Project M4 Body and Facial Hair
help! every time i use this the body disapers but the hair is there.could someone tell me the right way to load this??
  • Richard HaseltineRichard Haseltine Posts: 111,382
    edited October 2016
    You are meant to load a second M4 and apply the moprh that slightly enlarges the mesh to make an overlay, or in DS simply add a Geometry Shell from the Create menu, and then apply the material to that so that you get the hair on top of, and slightly clear from, the skin.
    You are meant to load a second M4 and apply the moprh that slightly enlarges the mesh to make an overlay, or in Poser simply add a Geometry Shell from the Create menu, and then apply the material to that so that you get the hair on top of, and slightly clear from, the skin.
    Shouldn't the geometry shell be in DS and the 2nd M4 in Poser?
  • oops, fixing.
  • LinwellyLinwelly Posts: 6,070
    Shank, to make that product efficiently work on g2m you need to have this product as well http://www.daz3d.com/michael-4-for-genesis-2-male
    else you get into shenaningans. on genesis male it should work without problems, find out how to make it work on a g3m here http://www.daz3d.com/forums/discussion/comment/1683056/#Comment_1683056
