Iray not rendering in the desired resolution :/
not really sure where to post this so, any mods are free to move it to the proper section :)
Now onto the reason for the post, so... recently i found out Iray now works with the 10 series (at least 1070), so i decided to give it a shot again, last night i rendered 2 test images in 1200x1400 resolution, i wanted to expirment a little bit more with Iray and get to know it more, so i decided to fire up DAZ this morning and decided to do some test renders to work on my skills, but... when i put in the desired resolution that i want to render in, Iray dosent wanna do it, instead it renders the viewport, even tho i havent selected the view port as the render source, now i have tried to restart DAZ, make a new scene, before i decided to uninstall DAZ, i wanna see if anyone here has experienced something similar and if you found a fix for it...
Also before i have people asking for images of my settings, i have attached a screenshot of the render settings :)
589 x 442 - 28K
  • fixmypcmikefixmypcmike Posts: 19,739
    Known bug, fixed in 4.9.3.123
    In the interim, if you have a scene with render dimensions set (globally or on a specific camera), try loading that and seeing if it results in the correct dimensions.
  • where would one find this interim?
    Until another public beta is released with the fix, if you have a saved scene with the dimensions you want you can load that.
  • aight, thanks for the help :)
