From Hero To Zero.
ghastlycomicghastlycomic Posts: 2,531
If I adjust a value of a figure/prop/etc. How do I make that new value the new zero for that figure. Like if I scale it up to 107 and make the y translate 88.5. How can I have the size and position of the figure stay there but now be the zero point?
  • Richard HaseltineRichard Haseltine Posts: 111,859
    You can't make it the zero point, but you can memorise the state and restore to the memorised state which achieves much the same thing. There are submenus for Memorise and Restore in the Parameters pane option menu and in Edit>Figure and Edit>Object. These apply to a whole figure or to a node rather than to a single property though - you can set the default value for a particular property in the Parameter Settings dialogue (click the gear icon on the slider).
