a question about files .exe
I ordered a product from the store and I get two files to download. One ends with trx.exe and the other is dpc.exe
I use studio 3.1.2.24
Thank you for any help
dpc.exe is the one you want.
The product is a new release called "Curator Aquarum" for $1.99
The answer to your question is "it depends..."
* Some items with both Poser and DAZ|Studio installers have only D|S materials presets in the D|S installer, which will usually have a much smaller file size than the Poser installer. You will need to run both installers.
* Some items have full Poser and D|S installers, you will only need to run one or the other, and the file sizes should be not too different. (They won't be the same, because of the different way Poser and D|S do things.)
* Many items released in the last year or so include D|S files in the Poser installer. In this case there might not be a D|S installer.
* Many newer items will only work in D|S 4 or 4.5 — these should have "trx" in the file name, although some have the "trx" when they shouldn't (work OK in D|S3) or don't have it when they should (usually texture sets for Genesis stuff, which can't be used in D|S3 anyway).
It should tell you on the store page if any of these apply, but sometimes the store page info is... less than completely accurate. If this happens, the DAZ 30-day return policy is your friend.
I am a bit confused myself to be honest now. I see DAZ format listed so in theroy it should work.
My advice is to pop over to this thread JACK TOMALIN APPRECIATION SOCIETY [JAS III][/ul] and you can either ask the man who man the product or another might see it and advise. I dom't have it myself otherwise I would take a look having DS3A installed and been used too.
well put SpottedKitty
Just noticed you mentioned which item it is — most of Jack Tomalin's stuff seems to be made for D|S3 (and also works in 4.0 and 4.5). The few recent things he's done with 4.5 files have, I think, every time also included files to let it work in D|S3 as well. In this case, the Poser installer has D|S3 files included in the MATs and the D|S installer has D|S3 scene files. You should be OK, then.
