Issues with Daz 4.9.3.117 Doesn't render
Hello,
I just installed the newer version of Public Beta and I got some issues:
- First, all the content doesn't appear in content library. The names are there but no icons to click and load them. That isn't the most important issue though. I can usemy previous DAZ 4.8 to create the scene, save it and render it with 4.9 (since it loads without problem there). But if anyone could help me with this that would be cool too.
- Secondly, and most importantly, when I load a scene and hit Render, the Render window (with "rendering image") appears for a fraction of a second then disappears, and the render image, well, doesn't render at all.
I have the GPUs (2 nvidia GTX 980ti) selected, CPU unselected. Work with Windows 64bits.
Thank you for any lights.
Tye lack of icons probably indicates that you have that section of the pane collapsed - reloading the layout (Window>Workspace>Select Layout) should fix that, but less drasticaly there should be a darker area in the frame border above the empty space (if your folder list is at the top) or to the right (if you use Side-by-Side) which collapses/expands the assocated sub-panel.
On your crash, there seems to be an issue affecting a proportion of users - it is discussed in the main beta thread http://www.daz3d.com/forums/discussion/95436/daz-studio-pro-beta-version-4-9-3-117-release-candidate-2-updated#latest
Thank you for your help.
I seme to have a rendering issue that I asked in the forum post you indicated.
