Legacy UVs for Genesis 3 - M4 problem
Hi!
I have problem with Legacy UVs for Genesis 3 - M4.
On Tight became strange black line. See on picture.
I had transform Material with Michael 4 Skins Batch Converter
What am I doing wrong?
  • Please post an image that doesn't show the groin area, or which has clothing on the figure.
    It may help if you list the steps you are taking to apply the materials to the figure.
  • Hello, goltnik.  Could you post another picture which will not be removed?  I have only just seen this post so I missed the picture, and have no real idea what the problem is.
    I bought this product and since I don't have that many M4 textures to begin with I've started off just by converting 1 M4 texture to DUF format. I then follow the instructions for using that M4 DUF texture on my G3M character. It works, partly, but the problem is on the head, shoulders, groin, and thighs there is still this clear blue area and those areas are still there even after applying the M4 DUF texture.
    How do I fix that.
    Also, why is there no Legacy to G3F product?
  • Nonesuch, the blue geografts have to be selected in the Scene tab when you apply the textures.  Normally when you run the Prepare script they will all be selected automatically.
    I am not sure what you mean by "Legacy to G3F".
    Thanks Cayman Studios. Something I have as a child mesh or something was causing problems with the selection of all your Legacy UV child meshes of the G3M character. Now it works. Thanks.
    Now however, by Legacy to G3F I mean a product for using textures from the Victoria 4 to Genesis 3 Female similar to the Legacy UVs for Genesis 3: Michael 4 - i-e- Legacy UVs for Genesis 3: Victoria 4 is what I'd guess you'd call it.
    The V4 product (as well as one for G2F) is over at Rendo.  It was released there before I became a PA here at Daz.
    Thanks
