How do i move my model around?
After i select my model (Aiko 6), i am unable to move it around. I did it before, but it is no longer working. I think its my computer's fault. Anyway i can fix this?
    How are you trying to move it?
  • How are you trying to move it?
    By clicking my right and left mouse buttons.
  • Richard HaseltineRichard Haseltine Posts: 111,325
    edited October 2016
    On what, where, with which tool active?
  • On what, where, with which tool active?
    I tried them all.
    Can you explain your exact steps?
  • Can you explain your exact steps?
    I just needed to reboot my computer.
    I moved it, but i ended up bending her and not moving her the way i wanted to.
  • I can't move it anymore. It worked once but i made the model bend over rather than moving it. I moved it by using the right mouse button and that stopped working.
  • Also, i am unable to put clothes on a second model. I opened up another Aiko 6 and the clothes won't go on her after i click it. I got clothes on my first Aiko 6 model but i was unable to do that for my second one.
  • Ok, i moved the models and have clothes on them. I have another problem. When i change hair color and make it darker, not all the hair will change color, the inner part stays the same color even when i edit the color of both the outer and inner hair.
    I did it, i had to change the base color. The new version of DAZ is too hard to use.
    I can't figure out how to move my model without making the body parts bend and move around. Can anyone help me on that?
    You really aren't providing enough information, but it sounds as if you are using the Universal Tool to drag on a body part down the hierarchy. to move a figure without posing it you need to have the figure itself or the hip seelcted, and you need to move it using the arrows on the viewport widget or the sliders in the Posing or Parameters panes.
  • sstolzsstolz Posts: 0
    There really needs to be instructions on how you move models around without changing them. I've tried every single tool, and nothing moves the entire model. There must be a way to do it, but it's not obvious at all.
