Import Image sinto DAZ
Is it possible to import images files (photoigraphs) into Daz?
As in, place a image of a person into an environement, so you can mould the environments and props around the image?
Ta  Porl
  • I'm not sure it's what you mean, but you can place an image on a plane primitive (Create>New pPrimitive and set teht ype to plane), resized to match the proportions of the image - use the Surfaces pane go to the Editor tab, select the Default surface, find the Diffuse Colour or Base Colour, and click the little square icon to the left of the colour picker then select Browse and load your image. That will give a solid plane - if you want just the figure you will need an opacity map, whiter on the figure and black everywhere else, loaded in tho the Opacity property.
  • SimonJMSimonJM Posts: 6,108
    You can also add the image as the background image, using the menu options: Window> Environment then changign the Type dropdown to be Backdrop.  When the window has updated with the new controls, the Background item will have tehstandrad Daz Studio colour options, including the dropdown selection box on the left which will give you the option (amongst a few) of selecting an image to use.
