Liquid Metal Texture Suggestion
Hello Everyone,
I'm not sure if this product already exists but I'm looking for a skin texture that can give me the effect of liquid metal like Terminator 2 or Colossus from X-Men. Please provide a link so I can get it.
Thanks in advance.
1280 x 720 - 62K
Post edited by aaronleescribe on
Which renderer?
Just use a metal shader and apply it to all of the surfaces. It's the same way you use stone shaders to create the illusion of statues. :)
You would select the surface, then look for a shader (or shader preset) in your content library. For example, Chrome.duf is in the default lights and shaders if you are using the 3DL shader. Or maybe you purchased a shader product like Advanced Metal Creator, or whatever.
You could probably create a basic metal shader by manually messing with the parameters in the surfaces tab too, but it would be a lot easier to use/modify an existing product.
Important, remember reflective things look that way because they reflect what's around them, so you'll need a skydome or the iray equivelant, or a material with faked reflections.
Well, it matters, in that a 3DL shader won't work in Iray and an Iray one won't work in 3DL...
Now, that said. The chrome mentioned above, for 3DL NEEDS either a 'reflection' map or a full environment.
There are several metal presets in the Daz and Nvidia Iray folders...
