Graphmate Graph Doesn't Appear
Okay, here's the thing. I'm working on an animation, only to find that when it starts playing, it goes by way too fast. I heard that I could correct this using Graphmate (which I have already purchased and inputted the serial number), but when I bring it up in DAZ, no graph line appears. I can move the camera about and zoom in and out, but that's it. There's no graph, so I don't know what to do.
Any idea what I'm doing wrong?
  • barbultbarbult Posts: 27,474
    Have you tried any of the online tutorials? Here are some that might help:
  • In order to see the lines in Graphmate, you have to first select a node (like, thigh or leg). Afterwards while in it - in the Parameter Tab - you can hover your mouse over a parameter (like Bend, Twist or a Pose Control/Morph) and you will notice it gets high-lighted. That parameter will now appear as a curve in GraphMate.
    You can select several Parameters at once by holding CTRL while hovering over them. (no clicking required).
    Does this answer your question?
