IRay refuses to render UberEnviroment2 lights.
No matter what I do I can't get IRay to render any UberEnviroment2 lights. They work just fine with 3Delight but not IRay. I turned Enviroment Mode to scene only and Auto Headlamp off...no effect. Rendering point lights works without problem.
Anyone have any suggestions what the problem might be?
  • fixmypcmikefixmypcmike Posts: 19,735
    UberEnvironment is for 3Delight, it won't work in Iray.
  • That...explains things. Thank you.
    Generally, the things that are for a specific render engine are lights and shaders.  If the product page doesn't say whether they are for 3delight or Iray or both, here are a few guidelines:
    1 - Except for the Uber Iray Base that's included in the DS Lights and Shaders, all the Uber products are for 3Delight
    2 - All the Age Of Armor (AOA) lights and shaders are for 3Delight
    3 - If they just say they're for DS and don't specify, they're probably 3Delight
    4 - Lower SKUs (below about 22000) are probably for 3delight.
  • However, the HDR images that come with uberEnvironment lighting sets may well be usable as environment maps in Iray - Render Settings>Environment group.
    If used, they are not suitable for use as backdrop images, also.  They are rather low resolution and 'pre-blurred', so while they will work for light, they won't as a backdrop.   They may also need to be adjusted from the default Environment levels.
