Reorganizing Parameter Categories
I wish to organize the morphs listed under Parameters > Actor > (subcategory) to suit my needs. I can create the category(s) in the proper place, but am now faced with switching the path for each morph individually in order to have it appear where I want. Is there a method of choosing a bunch of morphs and changing their path as a batch?
Right-click on the Parameters pane and select Edit Mode (if it isn't already)
Select the properties you want to move to a particular group (click, shift-click, cmd/ctrl-click work as for other kinds of selection)
Right-click on ne of the seelcted properties and then Set>Property Group...,
Set the desired group and click Accept.
Perfect! Thanks!
