Main Tab (actors, wardrobe and props) greyed out
Hi,
probably something with an easy solution, but my main tab is greyed out. Just a simple grey plane, can't see anything besides it. I can load props into it, just can't see anything.
Everything shows normally in pose, lights and render view, it's just the main (A,W &P tab) that isn't working correctly.
Guessing I accidently hit a combination of buttons to enable or disable something; a quick google search didnt get me an answer.
Cheers in advance for any help.
J.
  • Ah, do yu mean that the viewport is missing? If so, you can reopen it from Window>Panes(Tabs)>Viewport, then if the whole pane group was closed (which sounds to be the case) drag the top frame edge up to the top of the empty space until you see a line of the highlight colour and let go to dock it back in place. You can also reload your layout from Window>Workspace>Select Layout, but that will reset the whole UI.
  • OstadanOstadan Posts: 1,133
    Sometimes if you inadvertantly type something into a filter field (e.g. in the Scene tab) lots of things will disappear or grey out, and it can be very mysterious until you notice what you did.
  • Solved,
    It was indeed the viewport that was missing
    Thanx for the reply
