Das Studio 4.0.3.47 startup log errors?!?
bringhobringho Posts: 241
Dunno if this is anything to bother about bur I've found a few errors logged
while starting up a clean reinstall of Daz Studio PRO 4.0.3.47
Main question: Is my installer faulty?
1) Two dll's fail to load:
C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzautoriggercontrol.dll failed to load
C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzoptitexclothcontrol.dll failed to load
2) I don't use a 3D mouse so the third WARNING can be disregarded I guess...
3) The four missing assets seem to be a part of : "Script Development Kit" ?!?
4) Finally, what is this about?
"JSON interpreter warning: Unexpected string member: region"
Any advice appreciated.
+++++++++++++++ DAZ Studio 4.0.3.47 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.7.0
Running on Windows 7, Build 7601, Service Pack 1
CPU String: GenuineIntel
Stepping ID = 5
Model = 10
Family = 6
Extended model = 1
CLFLUSH cache line size = 64
APIC Physical ID = 1
The following features are supported:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
CPU Brand String: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Cache Line Size = 64
L2 Associativity = 6
Cache Size = 256
Total Physical Memory: 12279 Mb (12875546624)
Available Physical Memory: 8131 Mb (8526696448)
Total Virtual Memory: 8388607 Mb (8796092891136)
Available Virtual Memory: 8388422 Mb (8795898875904)
Current Memory Usage: 33%
C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzautoriggercontrol.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzautoriggercontrol.dll: Det går inte att hitta den angivna proceduren.
C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzoptitexclothcontrol.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzoptitexclothcontrol.dll: Det går inte att hitta den angivna proceduren.
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Asset : Scripts/Script Development Kit/Copy Lesson Strip Samples.dsa could not be located
Asset : Scripts/Script Development Kit/Copy Lesson Strip ToolBar Samples.dsa could not be located
Asset : Scripts/Script Development Kit/Copy Scripted Renderer Samples.dsa could not be located
Asset : Scripts/Script Development Kit/Copy Shader Samples.dsa could not be located
  • fixmypcmikefixmypcmike Posts: 19,738
    Did you just upgrade, or are these new errors? Do you own the Dynamic Clothing Control?
  • bringhobringho Posts: 241
    Thanks for your reply Adminstrator!
    No, I've been using 4.0.3.74 since it became available.
    Yes, I tried re-installing the Dynamic Clothing Control (even though I did not reinstall it after my last total uninstall, flush and reinstall one or a couple of months ago).
    During install it gave me a strange error message regarding not finding the old uninstaller... But it installed ok and then an original third error message disappeared.
    These two are the ones that still linger.
    Are you sure the Dynamic Clothing Control installer matched the DS4 version? I'm guessing it was an older version.
    Downloaded it again today and it's the same as the one I have so that is not the problem.
    Thanks anyway :-)
