Can I make a figure of a prop?
dyretdyret Posts: 191
Is there a way to make a prop or hair item into a figure wich conforms to Genesis?
  • rek_2158272rek_2158272 Posts: 0
    I think it should work if you use the transfer utility. Maybe use the 'Convert prop to figure...' command in the geometry submenu in the edit menu. Not sure, though.
  • dyretdyret Posts: 191
    thank you. "convert prop to figure" works great :-)
  • wancowwancow Posts: 2,708
    NO YOU MAY NOT! I forbid you to do it! You absolutely MUST NOT! :P :P
    But have fun doing it anyway :)
    What you might try doing is go to r.com or wherever, download clothing and translate it to Genesis. You'll need Victoria 4 shape for Genesis or Michael 4 shape for Genesis depending on the clothing you're converting. I found doing this helps one understand how conforming anything works with Genesis
    Parden?
