problems loading Genesis figure from Poser library
Hi,
I am having trouble loading my Genesis figure after saving it to the Poser library. Here's what happens: I made a child figure which I saved to the figure library. If I reload this figure into a new file, it comes in correctly proportioned. However, if I save the new file and reopen it, the figure comes in as an adult size. It retains its pose and the facial morphs but has adult-sized and wrongly proportioned limbs. You can see from the images that the adult figure has the same body dial settings as the child. Also, I do not see the DSON loading bar come in when I reopen the saved file. I'm assuming that for some reason the DSON loader is not working properly for the library figure. I am using the importer 1.0.0.27.
My workaround is to simply save all figures by saving and reusing my original PS3 files. I think I should file a bug report on this. How do I go about doing that? Thanks.
Zaffer
Images removed - please replace them with the figure grey rather than flesh-toned
Some people are having the same issue, I've seen it as well, but not anymore after I set my preferences to use external binaries.
Report the bug here: https://bugs.daz3d.com/login_page.php
Thanks WimvdB,
I do have that preference set to external binaries. I will file the bug report.
Zaffer
Just tried to file a bug report, but the bug report login would not accept my username/password -- I contacted technical support.
You need to make a new account. There is a link for it on the login page.
It will give you (almost) immediately access
