Pinning heels pose in DAZ
Hello. I have a question if it is possible to pin heels pose in Daz so that poses that come with heels don't set this pose when my figure has flat shoes or barefeet or when a pose has flat feet worn heels won't get reset and I have to apply the heels pose that comes with the shoes again after each pose I test. I know I can lock the nodes/bones but then for instance for a walking pose I have to unlock the feet manually and adjust them. Also the problem is that some pose presets use pose control and seem to use bone rotations (is that correct?).
Is there some way to work around this problem or maybe a product, that fixes the feet and toes bends?
Thank you.
  • Thomas WindarThomas Windar Posts: 272
    edited October 2016
    You would need a special script for that. If I understand what you want...
    You basically want something that RECOGNIZES when the foot pose will change and will APPLY it or NOT APPLY based on the TYPE OF SHOES (or lack of) the model is wearing.
    Yeah.... I doubt there is a function like that in Studio itself.
    EDIT:
    Here's a solution though. You can always select the whole model and its children nodes. Then de-select the feet nodes. Afterwards hold CTRL before applying the pose and choose to apply it to "Selected Only". That should kinda work I guess?
    Post edited by Thomas Windar on
