Hard drive changed - Stuff does'nt load anymore
Hello. I recently changed my PC config, and reinstalled all my DAZ 3D Stuff on a new hard drive. When I try to load .duf scenes, DAZ doesn't find the 3D Content - as the path changed. It actullay loads the scene under solid box aspect. Is there a way to teach the new hard drive location for 3D Stuff so that the scenes loads correctly ? Thanks for your help.
Edit>Preferences>Content Library, click the Content Directory Manager button and make sure that the paths are set correctly (you should be pointing to the folder that contains the Runtime and daat folders). If you install manaully you may end up with the Runtime and daat folders in a Content folder in the folder you are pointing to, you should move the files and folders out of the folder named Content and into the parent folder
