Animate 2 Crashes Daz Studio
Granville
Does anyone know of any limitations on animate 2 (pro plugin) ? I was attempting to extend an aniblock. But Daz studio crashes everytime at 1000 frames. Also Animate doesn't seem to take the frame length setting from keymate.
- What can I do to get 1440 frames out of Animate 2?
- How can I avoid crashing?
I apreciate the help.
I might be a bit off the mark here, but what you're saying is a bit confusing, so i'll ask for a bit of clarrification.
Regarding "frames".
Do you mean a number of aniblocks, frames in the aniblock(blue/green squares) or are you referring to the numbers above the line where you place the blocks?
The main reason i ask this is that aniblocks and the animate time line are measured in seconds, not keyframes.
So if the time line above the animate editor is showing 1000, it's 1000 seconds and not 1000 keyframes.
IF that's the case you're assembling about a 16 minute animation and maybe overloading your computer causing the crash.
Now if the block itself has 1000+ blue/green blocks in it that's about 34 seconds of animation at 30fps, that shouldn't crash daz studio, maybe.
I've personally strung together several minutes of animation in animate with no crashes, rarely get past 5 minutes as it takes forever to render out 9000 frames.
The keymate issue is because keymate is for Time Line(tab) not animate, so you'll have to convert the particular aniblock over to time line(tab) to use that data from keymate. AFAIK.
