SOLVED: Eloiny Hair Scalp Poke-Through
xyer0
Hello, Dazizens. This is my first time using this hair, and I wanted to use it without the hat. I did some minor morphing adjustments, but when I did a once-over I discovered scalp poke-through in the crown. The hair has no TopFull morph or HeadSize morph, and I'm befuddled as to how to fix it, except to maybe add 3Dream's hair cap. Any ideas, suggestions?
800 x 1067 - 1M
Post edited by xyer0 on
try a smoothing modifier (edit > figure > geometry > apply smoothing modifier) with collision set to the figure, should fix it right up.
I think this will happen only if you just parent it instead of using autofit. But autofit often distorts the hair, parenting only will usually fix this but will require some manual adjustment instead. Scaling x, y or z or all can often fix it.
That sounds like a great idea, and it fixed it right up like you said. Thank you so much FSMC. I only used smoothing modifiers for clothes. How silly of me.
It's a G2F hair, and I have not experienced any autofit problems from them to G3F. But sometimes hair or clothes items lack X, Y, Z scale sliders. I don't know why. And I don't know what to do about it either. Thanks for helping.
FSMCDesigns, Thank you also for listing the full tab flow for the functions. I knew where it was, but I've found that a lot of people that would otherwise be very helpful neglect to tell HOW to find in the program what they are explaining in the thread.
