Camera Views in Render Mode
I have accidentally removed or somehow delted the controls that let you select the camera from which to render when you are in the render settings and options window, there use to be like a floating dock in the viewport of the render tab that let you change cameras it is now gone and i have not been able to get it back, i use that to change views without having to move cameras, any ideas, TIA
  • fixmypcmikefixmypcmike Posts: 19,742
    If you use Docked view controls it will be in the upper left of the viewport, if you use the Cube it will be in the upper right; if the right side of the viewport is getting covered up by the right-hand tabs then try removing Shader Builder and Shader Mixer from the center dock.
