Buttom Shortcuts for Common Commands
Is there a way to create clickable buttons to enact macros, or actions already native to DAZ Studio? I have some commonly used commands (such as edit > figure > restore > restore seclected item(s) pose) that I would like to simplify for sime saving and convenience purposes.
Thanks!
  • Window>Workspace>Customise. Open the Tool Bars tab on the right and find the tool bar you want to use (or right-click to create a new one), then find the commands on the left and drag them into the tool bar. If they don't already have icons create one, then right-click on the command in the left hand panel and add the icon.
  • Personally, I am against the idea of cluttering my toolbars with too many icons especially when some of the actions do not have any associated icons. I could have saved hours of effort if Daz provided a keyboard shortcut for zeroing a selected figure's pose/shape. I would rather be contended with a keyboard shortcut in most cases.
    However, there is a file "actions.dsx" under "C:\Users\<username>\AppData\Roaming\DAZ 3D\Studio4" which contains command shortcuts as:
    <Action Accel="Ctrl+N" Class="DzNewAction" ShowTextWithIcon="false"/>
    I haven't tried modifying that file manually but I am willing to experiment if someone from Daz attests that modifying it is safe (i.e. not overwritten when adding commands/action through the studio).
  • fixmypcmikefixmypcmike Posts: 19,710
    You don't need to hack the .dsx file, Window > Workspace > Customize will let you add or change keyboard shortcuts, you don't need to put them on toolbars.
  • You don't need to hack the .dsx file, Window > Workspace > Customize will let you add or change keyboard shortcuts, you don't need to put them on toolbars.
    Thanks a ton.
  • Thanks for the reply! I will try that shortly - great!
  • macleanmaclean Posts: 2,438
    edited September 2016
    You can also add content to the Custom Actions. Right-click any thumbnail in the content pane and choose 'Create Custom Action'. You'll find your new action in the Customize pane under Custom Actions. You can then add a shortcut to it, or drag it onto a toolbar. (You can give new toolbar buttons icons too).
    It's very handy for frequently used content, like a Genesis figure, MATs, light presets, etc. Or even entire scenes.
    Post edited by maclean on
  • That's excellent, maclean, thanks!
  • I got all the restore/ zero/ memorize/ save preset/ base shader one click buttons out on the menu...
    One of Daz Studio's great virtues = custom interface.
    https://daz3dcookbook.wordpress.com/customising-daz-studio-menus-toolbars/
    http://snowsultan.deviantart.com/art/Customizing-DAZ-Studio-Interface-Tutorial-1-309379885
    http://snowsultan.deviantart.com/art/Customizing-DAZ-Studio-Interface-Menus-310684759?q=SnowSultan/37289683&amp;qo=17
    Making buttons is fun. My menu bar is like Sketchup
