Wet and Tanned Skins for Genesis 2 crash with tattoo
BellaBella Posts: 455
edited September 2016 in Daz Studio Discussion
Hello,
first time I'm using Wet and Tanned Skins for Genesis 2 - tested and it works ok with normal characters and Daz  goes but it makes Daz crash if my character has tattoos, applied with Layered Image Editor. I've tried to save the material and apply it on the figure but I always have a crash - any chance to solve this?
should I attach the error log? it's pretty long...
thank you :)
Post edited by Bella on
    Find the LIE created .png files in Studio's temp folder.  Create a LIE folder inside the Runtime/Texture folder of your library folder.  Copy the PNGs to the new folder, give them more sensable names if you wish then in Surface tab assign these.  Save then clear the scene, hopefully when reloaded Wet and Tanned will not conflict since they are no longer seen as LIE generated.
  • BellaBella Posts: 455
    Thanks for your answer, I tried what you said but it didn't work...
    i also tried to place the png file in the same folder of the original ones, but it crashed - I converted it in a jpg but still crashed
    I'm puzzled - can't understand what's wrong ...
    Looks like I've found a solution:
    I've saved the image file (turned into jpg) from LIE with tattoo in the very folder of the original textures of the character and I renamed the file so that it has the name of the original file (that has now another name)....anyway it's very strange :)
