Trying to reinstall a older version of Studio
dbdigital2
Okay I have been using a older version of 4.8 (I don't know the number off hand but I installed it June 1 of last year and it was current as of that time). I finally got around to installing the latest version of 4.8 (4.8.0.59 to be specific) and it wiped out the content database (or it isn't reading the older version). I didn't do a export beforehand BUT I did backup the entire database files manually. Crazy me thought that would do it if I had a problem. I do have a older export but I would lose a lot of data if I used that.
So what I am trying to do now is install the previous version of 4.8 I had installed so I can restore the content database, export it then reinstall the 4.8.0.59 version of studio. The problem is the older installer I have is a install manager version and requires DIM to do it. I have tried a few things like sticking the original files in the DIM download folder and restarting IM but no dice. I am guessing I need to alter the manifest files as well before it will let me revert.
I suppose I could uninstall it with DIM, but I was thinking that would zap all my settings/customizations as well. I have never uninstalled studio, but I know some software does delete user settings, while others don't. Any help is appreciated.
If you Work Offline in DIM you should be able to uninstall the existing version of DS, then install the older version from the zip. Though I am not sure how what you are seeing would happen with a version update.
Surprised me too. I never had this happen with a update before. After the update when I fired up Studio it took a long time at the "connecting to CMS" message then when Studio finished starting it promped me to import metadata. I canceled that and now no metadata is seen (catagories are blank, smart content is blank etc), although the database files are still there so it didn't delete them.
Are you using PostgreSQL or Valentina?
Valentina at the moment. Something else I am upgrading, well once I get this fixed.
Well I uninstalled with 4.8.0.59 and reinstalled my previous version 4.8.0.55. Restored the CMS database files and no dice. The CMS is still showing nothing (no smart content or catagories), however I think I have found out why. Checking the log I found "Connected to CMS: PostgreSQL 9.3.4" So it is using Postgre instead of the Valentina. It must have been installed with the upgrade, odd I always thought that was a seperate install we had to do through DIM. Anyway, I checked and found PostgreSQL under controlpannel and uninstalled it. Copied the databases over from my backups (to be safe) and all is well.
Wish I realized Postgre was running, all would I have to do was uninstall it and restore. I could have kept the 4.8.0.59 version of studio. Ah well I will fix that shortly including doing a userdata export.
You would need to switch to use 4.9, and Valentina is prone to database corruption (one of the big reasons for Daz' switching) - it's possible your issues are down to that, not to the version of DS.
Oh I know it is prone to corruption. And I think I found out one of the big reasons for it, if you have both DIM and Studio running at the same time corruption occurs. After I made sure to never have both programs running at the same time, no further problems (the other problem is not to do a backup with the CMS service running or corruption can happen). Still it is easy accidently fire up DIM when Studio is running, and a good idea to switch. I have not got around to it. For a while it was necessary to stay with Valentina as Carrara could not use PostgreSQL Carrara has been updated, but it will take a long time to convert my Valentina database to PostgreSQL so I haven't got around to it.
And I am sure it is the version of DS I used as it installed PostgreSQL. And since I was still using Valentina, all my CMS data seemed to be missing. I installed 4.8.0.59 using a exe format not a DIM version. Apparently, the exe version of 4.8.0.59 installs PostgreSQL by default. Not a big deal now that I know.
I figured PostgreSQL would be a requirement with 4.9, but 4.9 has several aspects I dislike and I have no interest in using it.
