Materials not rendering correctly
Hi there,
I just bought the Uber+ Iray Antique and did a quick render on one of my objects.
My render on the right has a smooth metal surface and does not show scratches like the one from the product (left image).
Any suggestions on how to fix it?
Thank you!
_KN
956 x 494 - 425K
  • SimonJMSimonJM Posts: 6,106
    edited September 2016
    Which of the Shaders did you apply to your surface, and are you using Iray as your rener engine?
    I used BattleWorn Iron on the cube and Scratch Iron on the sphere
    1500 x 1200 - 1M
    Post edited by SimonJM on
  • scorpioscorpio Posts: 8,534
    Is the object UV mapped
    That's my guess, too.
  • KNKN Posts: 55
    @SimonJM, scorpio and mjc1016:  Thank you for your quick replies.wink
    You were correct.  The object was not UV mapped.  It works fine now after I added a UV map.
    Next questions:
    -  Do the materials work only if the objects are UV mapped?
    - Is there a way to apply the materials onto a non-UV  mapped object and resize them to fit the object?
    Thanks!
    _KN
    KN said:
    Next questions:
    Not necessarily...but the cases where they will work without UV unwrapping are few and far between.
    Yes, but not easily...you, at least, need special shaders for 3Delight (not sure if there is a 'projection shader' for Iray or not).
    Post edited by mjc1016 on
  • KNKN Posts: 55
    It seems quite complicated.  But thanks for your reply, mjc1016.  Have a great week!
