HELP with Electromancy for Iray
Hi. I can't change the color of the lightning. Whatever color I choose It's always gray. What I'm doing wrong?
Thanks!
1280 x 728 - 250K
500 x 647 - 70K
  • BeeMKayBeeMKay Posts: 7,019
    Try selecting the surface in the surface tab before applying the colour preset. Some items need the surface selected when changing materials.
  • It change the color in the viewport but not in the final render crying Still gray! crying
    What can I do now?
    Thanks!
    1280 x 728 - 234K
    440 x 569 - 85K
  • fixmypcmikefixmypcmike Posts: 19,742
    And you are rendering in Iray?
  • Hi Mike! Yes, I'm crying
    edited September 2016
    I have this product and never had any problems with it... if you give me a few, I'll do a step by step screenshot, so we can compare notes on where the process goes wrong for you.
    EDIT: Images...
    First, I set the background to black so I actually see anything.
    Selecting the prop.
    Selecting the prop in the scene tab.
    Applying the material (I use a double click here).
    A quick functional test by using the viewport render. A bright bluish light emitts.
    Changing the light to red by double click.
    Functional test by viewport render. The light now has a slightly reddish hue.
    EDIT II:
    The effects becomes more prominent if you are using the bloom filter. Here's an example using the default settings, which of course is overkill.
    And here it's for the green lighting:
    415 x 365 - 33K
    713 x 846 - 76K
    1009 x 432 - 76K
    1180 x 600 - 122K
    1113 x 656 - 54K
    1038 x 580 - 106K
    1301 x 703 - 84K
    1280 x 762 - 75K
    1078 x 767 - 79K
    Post edited by BeeMKay on
