is V 4.2 ...?
1234MATT1234MATT Posts: 220
edited September 2016 in Daz Studio Discussion
is V 4.2 ...?
1. supposed to be in the daz studio formats?
 2. poser formats?
 3. Products?
  4. Catgories?
 its amultiple choice question... the more i look the worse it gets. hahahlolo
http://www.daz3d.com/forums/discussion/109161/please-put-your-question-in-the-post-and-the-title#latest
  • fixmypcmikefixmypcmike Posts: 19,710
    Most V4.2 stuff is in Poser formats, except for DS-optimized material presets.  If you install with DIM it will show up in Products.  A lot of my V4.2 stuff also has metsadata so it will show up in categories (although I make my own categories anyway), but not all of it.
  • 1. supposed to be in the daz studio formats?
     2. poser formats?
     3. Products?
      4. Catgories?
    k thanks, i had to dig deep to find her and it just got worse... can you help with this pic? i dont have a clue, some of them havce poses in them some of them have products and materials
    3840 x 2160 - 728K
    It looks like you have the Daz Connect library listed as a Poser-format library.  Can you post a screenshot of your Content Directory Manager?
    You should not install anything for the gen4 figures with Connect.  If you find a product for them that is Connect only you should contact customer service and ask they fix it or refund it if they don't agree it is broken.
  • here is stuffin poser directory,....its all daz or poser stuff. I cant seem to do much with it and as you can see its a long list
    ...thnaks
    3840 x 2160 - 769K
  • That is not the list under Poser Formats, that appears to be a list of user-created categories (prsumably created by you at some point).
  • ok, the big question is how do i get rid of it and why did it happen...i dont have a clue what i didi to make that happen,,thanks
    3840 x 2160 - 523K
    I'm guessing you used "Scan Hard Drives for Files" and it picked up each Runtime folder.  If you didn't have a lot of content folders before, then the easiest way to fix this off the top of my head would be to create a new content set in Content Directory Manager with only the correct entries, then make that the Current set.  If you do have a lot of content folders, then I would suggest using the sample scripts under Directory Mapping here:  http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start
    to export the list, then delete all the extras in a text editor, then import the list back in.
