PINK Renders
Hello. Has anyone had this problem? Same for any item or scene rendered in Iray. Sample (!pink) was made with Default Iray setting.. size changed and Sunlight Only.. -- but any scene, any lights or no lights.. with or without Dome.. any content from Daz Cats thru newest releases. Thanks for any ideas. p.s.Has worked perfectly [GeForce GTX 745] until two days ago.
840 x 525 - 141K
A .dll that Iray needs has been quarantined by your Anti virus program. This is because it thinks it may be a virus or malware file, but this is a false p[ositive. your are probably using Kapersky, (there are a couple of other less well know AVs as well that do this. There are threads about this in the forum
http://www.daz3d.com/forums/discussion/111256/render-in-pink
http://www.daz3d.com/forums/discussion/102026/pink-object-after-iray-render
http://www.daz3d.com/forums/discussion/98576/virus-detected#latest
http://www.daz3d.com/forums/discussion/98756/iray-pink-render-problem
Thank you...
side} ya know, I used "Search" in the Forums and in Help b4 asking and came up with Zero hits that applied..
I Used Pink render and Iray in a search string along with Daz 3D Forums, and used Google. (Just so I could watch the cute rocks again)
