Daz Cyclorama +4.5
Vitachick
Use the cycloplanes quite alot. But seems 4.5 can't find any of my Daz Environment texture items..Not compatible?
Vitachick
Where are you looking?
I have MPCycForest2_QS.CR2 in Poser Formats > Studio 3 > Figures > Environment, and the corresponding textures are in the Pose Folder, in a folder called 'MAT MPCyc'.
Is that what you mean? It looks pretty good in DS 4.5, I may start using it again myself :)
i HAVE NP WITH DAZ3.. .IT'S 4.5 i HAVE THE PROBLEM WITH....
Even using the earch engine comes up blank..
You have 4.5 and it works?
I was talking about using it in 4.5.1.6. :) I haven't used DS3 for a long time.
Do you have the content folder for DS3 listed as a DAZ Studio formats folder in Preferences, and as a Poser Format as well?
yes. search engine does not find anything....I can manually look but shouldnt be this annoying
Is it installed to your DS3 content area? Where is it installed exactly?
Do you have the DS3 content folders listed as DAZ Studio Formats and Poser Formats in Edit > Preferences?
E:\Program Files\DAZ 3D\content
What OS are you using? If it is Win 7 or Vista, your content should NOT be stored in the Program Files area.
This is the most important part anyway.
Win XP32 bit and other comp is Win7 64 bit. Been the same for years np.. Only now with 4.5.
Ok Win7 comp where should the content folder be? I have Daz3 and Daz4 on two sep drives trying to avoid
a problem.
Fixed the problem with 4.5....I reinstalled all my Cyc to a partitioned drive. Now all shows up.. Just cud not
get it to work with Daz3 content at all....
Thanks all for your help!
