How many CUDA cores you have in your system?
I'm just curious laugh
Thanks!
«13
  • This is what I'm using:
    NVIDIA GTX 660
    960 CUDA Cores
    1072 MHz Base Clock
    1137 MHz Boost Clock
    85.7GT/s Texture Fill Rate
    Memory
    2048 MB, 192 bit GDDR5
    6008 MHz (effective)
    144.19 GB/s Memory Bandwidth
    Interface
    PCI-E 3.0 16x
    Old, I know... but I have a dream!!!  A 1080 when they get Iray so I can get a GTX980Ti 6Gb for cheap!  haha
    Zotac 980TI AMP Extreme x2
    2816 CUDA Cores (5632)
    6GB 384-Bit GDDR5
    Core Clock 1253 MHz
    Boost Clock 1355 MHz (mine run @ 1400MHz)
  • ermullensermullens Posts: 93
    edited September 2016
    24,576  8, M6000 quadro 24GB,384 bit GDDR5 3072 cores per card, GPU 988 MHz Boost 1114 MHz Memory 1653MHz,6612 MHz effective
    second twin ASUS GTX1080 Turbo 8GB Cores:,2560, per card, Base Clock:1607 MHz, Boost Clock: 1733 MHz
    House looks like an electronics store lots of gadgets very few clothes, unless you look on the wife's side begins more of a clothing/shoe store look then
    Post edited by ermullens on
  • 640 CUDA Cores, GTX 750 Ti.
  • hacsarthacsart Posts: 2,037
    None, zip, zilch...
  • Pack58Pack58 Posts: 750
    No laughing (or at least do it quietly) 192
  • AJ2112AJ2112 Posts: 1,417
    EVGA 670 FTW - 1344
  • DustRiderDustRider Posts: 2,911
    GTX 970M - 1280 cores
    Post edited by DustRider on
  • exstarsisexstarsis Posts: 2,128
    GTX 745 (OEM)  CUDA Cores 384
    I feel your pain friend, till Nov 2015 my previous card was 96
    Post edited by AJ2112 on
  • davesodaveso Posts: 8,251
    zero
    too little too late
    What's a cuda core?
  • boisselazonboisselazon Posts: 458
    number of cuda cores is not comparable between generations (maxwell, pascal, kepler etc...)
    Post edited by boisselazon on
    96...and that is most definitely NOT ENOUGH!
  • Where do I find this info?
    On this laptop: Nvidia GeForce GTX 970M 6gb 1280 CUDA - not enough
    I have a 6gb GTX 980Ti on my desktop with 2816 CUDA - better, but still not enough ;)
    Post edited by AllenArt on
    There's a small free program called GPU-Z that will give you all the info on your graphics.
  • Nvidia 780 6gb = 2304 cuda cores each. I have 3 so 6912 cuda cores. It makes for zippy Iray renders.
    The Nvidia Control Panel applet (or whatever they are calling it these days)...no need to download anything else.
  • GTX 780 (3Gb) - just over 2000 cuda cores
  • GTX 1080 - 2560 Cuda Cores which equals 0 for rendering right now as it's not yet supported in Iray  :)
  • AllegraAllegra Posts: 405
    I've no idea about cores either but I've a GTX670 and it zips through Iray.
    1344 according the Nvidia spec page...
    GPU-Z has a portable version...no need to install.
    Laurie
  • PetercatPetercat Posts: 2,324
    So... let me ask here...
    What's more important for iray, CUDA or card memory? Or system memory? I rarely get tossed into CPU rendering, but when it happens, it's bad.
    Nvidia 980ti, 32G 3200 system RAM, I7 quad 3.4. Should I get another 980ti? Wait for 1080 support? Or double my system RAM in the meantime? Maybe an SSD.
    I remember, back in the stone age, when you could add RAM to your video card. They had empty sockets.
    I wish iray would use system RAM when needed, instead of the CPU. I'd be golden.
  • Nyghtfall3DNyghtfall3D Posts: 817
    Iray doesn't use or look at system memory.  Card memory is needed for Iray to load scene data onto your card.  CUDA is needed for Iray to render that data.
    As for the thread, I've got 5120 cores between a 6 GB Geforce GTX 980 Ti and a 6 GB Geforce GTX 780.  I'm going to replace the 780 with another 980 Ti in a few months.
    Post edited by Nyghtfall3D on
  • L'AdairL'Adair Posts: 9,479
    +1, sort of. On order with new computer, supposedly ships 10/4...
    So if I'm limited to 6Gig anyway, renders won't start any faster but adding another card will mean they finish faster?
    Yes...but doubling the cores (2x of the same card) doesn't cut the time in half...it does shave off a bit, but not that much.
