Iray Envirocam
I just bought RawArt's Iray Envirocam, which looks great, but I can't figure out what to do with it. I can't find any documentation or instructions on how to use it. I'm sure someone out there has figured it out. I really need to put some lightning in a scene and this looks like a good way to do it. Or is there a tutorial online that will show me how this works?
  • fixmypcmikefixmypcmike Posts: 19,738
    From the ReadMe:  http://docs.daz3d.com/doku.php/public/read_me/index/31793/start
    • How to Use:
      • Set up your scene as normal and load the EnviroCam.
      • Adjust your camera settings as you normally would.
      • Select the Enviro Panels in the scene tab and apply the Material Preset which you wish to use.
      • When using the individuals select the panel you wish to apply it to in the surfaces tab.
      • Adjust the panels through the general movement settings or through the Adjustment movements (or you can also move the panels individually if needed)
      • Then Render as normal.
    • The materials were designed to be used with the Enviro Panels, when using the materials with the single panel you will lose some of the depth of the materials.
  • melaniemelanie Posts: 807
    Thanks, I'll try that. I looked at the things in there and didn't even know were to begin. I couldn't find a readme.
    If you use Daz Install Manager, clicking on the Info symbol (letter i in a circle) on a product row will take you to the readme; otherwise, you need to plug the product SKU into the link I gave above.
    One last question (hopefully): where are the materials for lightning? I find rain, clouds, explosions, etc., but I don't see the lightning. It's listed in the product description. I can't find it in the materials list. Or am I just not seeing it?
    The lightning options show up in Content Library > Daz Studio Formats . [content library name] > Camera Presets > Iray > Raw EnviroCam > MATs > Individuals
    or in Smart Content under Materials:Iray:Props with the panels selected.
    Oops! Never mind. I found them!!! Sorry!   blush
