Geometric Shell - Question on saving a geometric shell as preset - SOLVED
cosmo71
Hello, I have a question on geometric shell saving as a preset.
As what I have to save a geometric shell as preset to have also the selected visibility (on/off) of "shell bodyparts" and "visibility bodyparts" next to the surface parameters?
Example: One preset should have a surface for the face next to the surface for the body, the second version not. So for the first version I turn visbility for the face "on" and have also the surface paremters for the face in the second version I want no surface for the face just for the body so I have no surface parameters for the face and turn the visibility for the face "off". Both versions saved as properties preset. If I load the first version I have both the surface for the face and for the body but I load the second preset I have the surface for the body but the default surface for the face and the visibility is not turned "off". So it seams that a shell saved as properties preset did not save the parameters for shell parts visbility (on or off) and also not the offset distance value. So it seams properties preset is not the correct one for a geometric shell.
SOLVED: Forgot to check also "others" in the save menu
