Install Manager and Daz Studio proper path clash
Hello, I can see only very limited number of resources in my installation of Daz 4.9. This may be due to the fact that install manager is installing stuff in a different path with thatof the Daz Studio proper's path. Common sense says they should have a understanding between them. OK, how to solve this issue?
1240 x 557 - 682K
To change the paths DS uses: Edit > Preferences > Content Library > Content Directory Manager
To change the paths DIM uses: Settings (gear in upper right corner) > Installation
There are sample scripts which you can run inside DS to import/export the paths between DS and DIM here, under "Directory Mapping": http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start
I did this once and it totally messed up my install. Had to remove everything and start again, without changing the paths.
What did you change, and what happened?
