Walk Designer
VIArtsVIArts Posts: 1,539
How do i load the animation files from Walk Designer for M4 and V4 in DS? I can only find the poses/
  • JaderailJaderail Posts: 0
    Time for a refund bro, those are POSER only for FULL features. They might work in Carrara but I do not know if they do or not.
  • VIArtsVIArts Posts: 1,539
    Haven't triedit in Carrara yet. I have a habit of building my scenes in DS and then rebuilding in C8Pro. I couldn't find any walk cycles that look casual.
  • dan.shivedan.shive Posts: 0
    I'm not sure what the issue is. The poses are animated and do work in DS. I understand there's functionality beyond that not included in DS, but it sounds like you just want a casual walk cycle.
    Yes, I do. But I only found the static poses in my Poses folder.
    Are the poses you speak of found under My Library\Runtime\libraries\Pose\WalkDesigner, and have you tried clicking on various frames of the timeline after applying one of the poses? No keyframes are added, so it might look like there isn't an animation being added, but in my experience, there is.
    If yes to the above and it's still just a static pose, then I'm not sure what's up.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,737
    try looking under pose/universal poses for the animations
  • 3DAGE3DAGE Posts: 3,321
    HI LOH :)
    The walk designer files should be placed "automatically" into a Poser Format's folder,. inside (Poses) called "Walk designer"
    The Basic animation can be used in either DS or Carrara,. but only poser has an actual animation mixer, (walk designer)
    which allows you to create a new walk style, by mixing values of the pre-set animations, plus any custom walk animations you've made.
