How to Use Poser skin Textures in 3Delight in DAZ Studio?
Are there specific things I need to know or do to get my old skin textures that were created for Poser to look good in 3Delight?
Thanks!
  • SorelSorel Posts: 1,434
    Apply another character's settings? ctrl+click, select to not replace maps
  • FauvistFauvist Posts: 2,290
    I don't understand.  How do I apply another charactrer's settings?  What other character?  One with skin made for 3Delight?  ctrl+click to not replace maps?  I don't get it.
    edited September 2016
    Load the figure you want with the Poser materials. Find a 3Delight texture set for that figure whose shaders look good to you. Hold down Control while you click the material file and then chose to "Ignore" the new maps when you apply it to your figure. It will transfer the shader but leave the texture maps as they are. Make sure your figure is selected in the scene tab and the Surface tab as you do this.
    Laurie
    Post edited by AllenArt on
    Laurie
    This ^ but more detailed lol.
    Post edited by Sorel on
    Thank you both!  I'll try to do what you said.
    Laurie
    The "shader" is what?  The settings that go along with .jpg?
    It's a Material file (most likely) or a single Shader file. There should be a small box over the thumbnail that says what it is :). Think of a DS material file as an mc6 and DS shader file as an mt5 if that helps. Oh, and yes..the shader is are the stuff apart from the texture maps. IE: gloss, refraction, diffuse, etc.
    Laurie
    Sorel said:
    Laurie
    Sometimes those of us coming from Poser need a detailed explanation. LOLOL. DS gets confusing real quick because it's so different :).
    Laurie
    Thank you again!  I'll try to make it work.
