Is this crease unavoidable?
Is this crease in the new Cathy hair fixable via an adjustment I haven't found, a flaw in the model, or unavoidable in long hair because of the conforming issue?
  • ToyenToyen Posts: 2,081
    Fully conforming items are following the body's movement. So unless the item is rigged with custom bones that you cna adjust or has morphs that you can use to overcome some issues, then there's not much you can do.
    This why hair should not be conforming and always have their own bones for posing.  It is high time to stop doing things the old and flawed way.
  • kaotkblisskaotkbliss Posts: 2,918
    The best thing to do is to un-fit the hair and just simply parent it to the head
    Then you can go to edit -> figure -> geometry -> apply smoothing modifier and have the hair collide with the figure so there's no poke through.
  • exstarsisexstarsis Posts: 2,128
    Thanks, re: the unfitting hair tip. I'll give it a try next time I pull out Cathy hair!
