Which Genesis UV Map?
DraagonStormDraagonStorm Posts: 748
edited December 1969 in Poser Discussion
Not sure if this is were I should be asking this...
Does any one know if there is any way using Python script in Poser to find out which UV map has been assigned to Genesis?
  • estheresther Posts: 641
    no, but if you want to change the texture and you are not sure you could always run the script to change it to what you wanted and then apply your texture I suppose.
  • sandmanmaxsandmanmax Posts: 992
    What script to change the UV? I've been trying to figure out how to do that.
  • DraagonStormDraagonStorm Posts: 748
    MEC4D UV Switcher Freebie will do that. But it not what I need.
    My products do overlay textures to existing textures, so I need to know what UV Genesis is using.
