Genesis skin shader help
nickalaman
Hi,
Wondering if there is a script or a way I can apply a value for glossiness and shininess to a figure after I've applied my skin mat. I can of corse apply each node manually but that takes too much time, espcially if i change my mind and would like to try different values.
Working with 8.5 pro.
Thanks,
Nick
There is no script as far as I know. One good way to do it is to select Consolidate Duplicate Shaders, once you do this then there are only 4 shader domains (V4). This is a little less time consuming, I do this all the time and it adds only about 5 minutes to my process.
Thanks,
Didn't know about the consilidate.
This is the Carrara forum, and "consolidate shaders" is a Carrara function.
Now don't I look an idiot which is no change...sorry about that. That's what you get for not being able to sleep for 48 hours and counting. I use Carrara and didn't know it exisited so at least it will help me. :)
