Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.9
Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.9+ (Win 32-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
    Do you have Photoshop?  If so, go to Settings (gear icon in the upper right) > Applications, click the + sign in the lower left, and add the version, bits, and path to the Photoshop application.  If you don't have Photoshop then you don't need to install the bridge.
  • Loner98Loner98 Posts: 2
    HOW TO INSTALL THE Photoshop 3D bridge for Daz Studio
    It is recomended that you use the Daz Install Manager to install this bridge or plugin, but before you install it please follow the steps below to avoid the "cannot find path error."
    1. Launch Daz install manager
    2. Click on the gear wheel on the upper right hand corner of the Daz Install Manager
    3. A window will pop up
    4. Click on Applications
    5. Click on the plus sign at the lower left corner
    6. Under Name click the down arrow and select Photoshop
    7. Under the Version click to select the version of photoshop you have installed in your computer
    8. Under the bit click select the bit version of Photoshop you have - example 32 or 64
    9. On the path --click on the grey box with 3 dots
    10. Another screen will appear do the following
    • Click on Computer or My Computer
    • Click on your C hard drive where you have your Photoshop installed
    • Click on Program Files if you have a 64bit Photoshop installed / click on Program Files (x86) if you have the 32bit version of Photoshop installed
    • Next screen click on Adobe
    • Next screen click on Adobe Photoshop CS (4)(5)(6) or (cc) depending on the version you have
    • On the lower right corner of the screen, click "Select Folder"
    Now go back to the Daz Installation Manager and install the  Photoshop 3D Bridge for Daz Studio again and it should install fine.
    pdf
    pdf
    How to install Daz Studio Photoshop 3D bridge for Photoshop.pdf
    20K
