Mil Big Cat Morphs?
sandmanmaxsandmanmax Posts: 992
I've been playing around with the Mil Big Cat since AM has a freebie fur pack.  When I loaded it up, I found out I can't actually use the morphs.  If I load a MAT pose, say the Cheetah, it will automatically dial in the cheetah form.  Isn't there any way to actually use the morphs independently if I want to create unique cat of my own?  There doesn't seem to be a morph injection that I've missed.
Post edited by sandmanmax on
  • LeanaLeana Posts: 13,640
    If you hold the control key when loading the preset you should get an option dialog where you can choose what to apply.
  • Do you mean the original Big Cat, or the Big Cat 2?
    Not sure if they're set up the same (I only have the original) but the MAT/MOR poses are not actually morph injectors, they only set the values for morphs that are already on the figure. Try looking in the Parameters tab, the morph dials should be somewhere in there.
